Brake testing system
Help:Design a brake testing system of a car such that:
1.Apply is Time steped on the brake,Release is release time, Count is the frequency of testing/detection times, Real Count is the actual count, start for begining, Zero is for reseting real count. Pause is for suspending operation, Stop is for ending running state.
2. Functional requirements: Apply and Release are combined into a counting cycle,for each cycle, add +1 to Real count, Count is used to configure the total count. When the value of RealCount is equal to Count, exit the program, click the pause button to pause count , re-click the start  button to restore count, click on the stop button to stop the program,then click zero after real
Message 1 of 8
(6,126 Views)
Sounds simple enough.  What is your problem?
Message 2 of 8
(6,122 Views)
Sounds like homework.
Message 3 of 8
(6,107 Views)
I can see from your post that you are having trouble making the lines to divide up the front panel. Press ctrl+space to bring up the quick drop menu on the front panel and type in "line". My favorite is "System Chiseled Line". Hold down shift to make it snap to 90 degree angles when you lay it down.
Message 4 of 8
(6,101 Views)
Just trying
Message 5 of 8
(6,083 Views)
Hi Rhinedi,
I think there is confusion about what you wanted help on. Obviously the forums is not a place where you say "I need an application for this, give me a solution". That is what hiring a contractor is for.
The forums are, however, a great place to post your VI and say "I'm getting stuck with this specific part, does anyone know how to handle it?"
Message 6 of 8
(6,064 Views)
I have tried to go as per the requirements and this is what I came up with,but when I run the program count,release and apply figures are just constant,only real count is changing,help check where I might have gone wrong or what might be missing.
Message 7 of 8
(5,988 Views)
Instead of using local variables, use a Shift Register to store your count.  Then you don't need the sequence structure and let dataflow do the job.
Message 8 of 8
(5,969 Views)
