Break in specific conditions
Pause in specific conditions, as the program is running, I have two user inputs, initial path to the end path (a numerical distance) when that distance being incremented according to the user entered (for example it can choose that each loop of 9 steps, or 5 or 10, depends on the user) and when it is incrementing according to the user chose, when it was equal to or exceeded 430 had a pause, and then the same process in 700 , had another pause.
(2,515 Views)
What's your question?
It sounds like you are trying to figure out how to use Boolean logic in LabVIEW to stop a loop?
Please include a Snippet of your code, or attach your VIs, so that we can better assist you. We are here to help, but won't spend all that extra time recreating your code from scratch.
Cheers
(2,508 Views)
You could also use a state machine to control your processing.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,469 Views)
