Breakout board for PXI-2569
Hi
I was recommended to get these for the pxi-2569 board.
Terminal Block, TBX-50, 50 Pin D-Sub, Test and Measurement Devices
NI Part No: 782866-01
Newark Part No.: 13AJ4043
Newark Product Link: https://www.newark.com/ni/782866-01/tbx-50b-terminal-block-test-equipment/dp/13AJ4043
Qty: 4 Ea.
I have the cable for the PXI-2569
I am looking for the aftermarket breakout boards for it if anyone can point me to them.
maybe something like this from amazon.
thanks for your help.
Krispiekream
(2,350 Views)
Which cable do you exactly have?
You can get this cable to split the 200 pos connector into 4 sets of 50 D-Sub connectors. Then you can get breakout board for the 50 pos D-Sub from the market.
here are some other options Google returned,
https://www.ni.com/en-us/support/model.lfh200.html
https://www.pickeringtest.com/en-us/products/connectivity-cables/cables-connectors/200-pin-lfh/conne...
https://www.mouser.com/c/connectors/i-o-connectors/?m=Molex&tradename=LFH
https://www.pickeringtest.com/en-us/products/connectivity-cables/cables-connectors/200-pin-lfh/addit...
Santhosh
Soliton Technologies
(2,337 Views)
Cable Assembly, 200-Pin LFH, Male (Male Screwlocks) to Male (Male Screwlocks), 2m - 40-970B-200-2m-M...
I believe I have that one
The part number for the cable is
40-970B-200-2m-MM
Krispiekream
(2,286 Views)
Accepted by topic author krispiekream
If you already have that cable, you can consider one of these as alternative to what NI sells,
Santhosh
(2,266 Views)
Thanks for your help!
ok, this confirms to me that we need to purchase one of these or buy a new cable.
THANK YOU SO MUCH!
Krispiekream
(2,246 Views)
Yeah, this is a fairly dense connector requiring very special cable and breakout that is quite pricey.
Santhosh
(2,240 Views)
