Bridgeview activities
While working through the Bridgeview activities I have had instances where
the main bridgeview OPEN_VI, front panel editor files/open or files/save_as
do not open the expected file windows. Bridgeview must be exited and restarted
to continue.
(2,729 Views)
Randall,
I was working for some time with BridgeVIEW 2 up to 2.1.1 but I've never seen something similar to your problem OR I do not understand your description.
If you still have problems with BridgeVIEW you might describe your problem in deep or you might consider to upgrade to LabVIEW 6.1 and the add-on module: LabVIEW Datalogging and Supervisory Control 6.1.
Hope this helps
Roland
(2,729 Views)
