Brightness / contrast settings on color -RGB64 images
Hello everybody,
I have some problem displaying RGB64. Is there any possibiliy to set the constrast / the brightness displaying the data? I know there is some solution for grayscale images and RGB32 images but I didn't found any applicable for RGB64. May somebody has a solution?
I have alos some trouble to convert RGB64 to RGB32 images.
Best regard
Joe
(2,740 Views)
Hi Joe16,
This could help:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019V3DSAU&l=en-US
The RGB32 images, uses 8 bits for every color planes, so I asume that the RGB64, uses 16bits for every color plane. Check the NI Vision Concepts.
https://www.ni.com/docs/en-US/bundle/ni-vision-concepts-help/page/nivisionconcepts.html
You can configure the the Image Indicator, to configure the display of these 16 bit images, in the Concepts Manual, you can see there diferent methods.
Let me know how it goes.
Tania Lozoya
(2,693 Views)
