Bring Excel 2007 to the front when called from LabView v9 in Windows 7
Thank you one and all.  I took the easier way out by calling the application property node a little later in the diagram with a minimize then normal again.  The API method would probably allow one simple call but would require me to study up on all the ramifications and settings.  Someday but not with customers tapping their watches.  Hopefully this will work out OK with WinXP since I also have to port the code back to the existing systems so all are the same.
Thank you again one and all for your persistent help.  One day the mystery will be explained.
Message 11 of 11
(600 Views)
