Bring to front
I'am novice french user, using Labview 8, and I need to upgrade an application design. But, when a drop a new component (decoration component) onto the design windows, it is automatically bring to front. How can I a put it to the back (behind all the other components) ?
I make Cut/Paste but this method remove the links of the object. Please Help.
(14,745 Views)
Hi Seb,
in the menu of the frontpanel you will find buttons for aligning, setting distance or size and ordering (front/back) of FP elements. Just use them!
And RTFM 🙂
(14,738 Views)
Yup, just like what GerdW said... the button is located at the top of the Front Panel, just below the File, Edit, View, ... tabs... the button name is Reorder... click on it n a drop down will appear showing Move Forward, Move Backward, Move To Front and Move To Back...
hope this helps... Smiley Wink
Best Regards,
JQ
LV 8.0 user...
(14,735 Views)
Ok thank you
(14,732 Views)
