Broken Semaphore VIs
@Yamaeda wrote:
@billko wrote:
One of the best tools for this is to simply display the complete path in the project window.  I forget how to do that right now because I don't have LV on this computer.  But by enabling this, you can usually see if a VI or control doesn't belong.
Do you mean shifting to File view? Ctrl+E or the Files tab.
I have access to LV now, so let's see...
Project --> Show item paths.
It shows the file paths, and usually a quick inspection will show you stuff that is in the wrong place.  For instance, maybe a file in your project has a path that you know is supposed to be a dependency path.  You automatically know something went wrong.  (It's up to you to decide whether that file is a dependency and moved into the appropriate library, or it's part of the project and should be moved into the appropriate project path.)
Bill
CLD
(Mid-Level minion.)
Message 11 of 11
(447 Views)
