Broken VI, but only from TestStand
I am trying to run a sequence from TestStand that contains LabVIEW steps. It aborts telling me that a VI cannot be executed, as it is most likely broken. It advices me to load it in LabVIEW and check. I do that and it loads and executes fine. I am confused and not sure what to do next.
CT
(2,455 Views)
Does your VI dynamically call any subVIs or anything that might not be in the TestStand search path?
Are you using the RunTime or Development Adapter?
(2,448 Views)
