Broken VIs in LabVIEW class without errors. Reloading projects fixes VIs
I have a project with a class inside a library. I was working on the VIs in the class and at one point I noticed that every single VI from the class was broken. However, the error list gives 0 errors. Also a simple VI that takes a private data element from the class with only a single unbundle by name appears broken. The class itself seems ok, there are no errors. All the classes in the class private data are all ok, same for their VIs. It is only a single class that gives the problem.
Reloading the project without any changes in the VIs fixes the VIs somehow. I've had this a few times after this, it's quite annoying. Does anyone know the cause of this problem?
I've attached some screenshots what I encounter. Let me know if you need more info.
Message 1 of 1
(1,949 Views)
