Browse for Folder dialog
This VI is very nice, but in order to broswe from a folder location other than NULL (root directory) you need a way to get a PIDL for a path....there is another shell function that should be in the Shell32.dll that can get the PIDL from a string, but it doesn't seem to be on my system...
I wish this stuff was better documented.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 11 of 32
(3,262 Views)
This seems to work well, the only thing needed now is someone to write a wrapper around the Shell32 call that allows us to pass in stuff like a starting path or a title string (it would go in that large blank area above the folder listing area).
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 32
(3,239 Views)
Mike,
That's exactly what I was trying to figure out last night.
Message 13 of 32
(3,232 Views)
Can anyone tell me how to make this vi a path control to subsitute the original one?
Message 14 of 32
(3,134 Views)
Hide the browse control for the path control and create your own browse button.
___________________
Try to take over the world!
Message 15 of 32
(3,126 Views)
Well, there is no "original one", just the plain file dialog that can select either folders or files. Most likely, you still need the "files" functionailty in the future, so use this as an additional subVI. Place it in the user palette if you think you need it often.
Message 16 of 32
(3,128 Views)
Ok I created a new button, works fine. But now I'm wondering if there's a way to save the last selected path as the default one, so that I don't have to browse from the top every time.
Message 17 of 32
(3,110 Views)
Hi ishi,
well, that's what was asked for in message #12 Smiley Wink
Message 18 of 32
(3,102 Views)
I don't know what was the ultimate solution to this thread but I am having a same problem.
I used .net 2.0 windows form but everytime it runs it just shows a dialog window with three buttons. The directory tree is not visible (or not there at all). Is it a windows problem or labview problem?
Thanks.
Message 19 of 32
(2,976 Views)
Message 20 of 32
(2,956 Views)
