Bruel & kjaer investigator 2260
Does anyone know if there is a vi available for the Bruel & Kjaer investigator 2260 or does anyone know how I need to set up a communication with this devices using LabVIEW?
In attachment the serial interface commands.
Thanks.
Joris.
Message 1 of 9
(4,416 Views)
On the Instrument Driver Network, there is a section on Developing Drivers if no one has something.
Message 2 of 9
(4,401 Views)
Hello Joris,
Do you have previous LabVIEW experience?
Have you ever done any communication with instruments before (serial, GPIB, ethernet, ... )?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 3 of 9
(4,378 Views)
I've noticed those driversbut those are all old measurement devicesTherefore I was looking if there where other drivers available.
No, I'm still figuring it all out.
I need to make this connection for my master thesis, so all the help is welcome!
Message 4 of 9
(4,374 Views)
Is the no about the first or the second question?
Or about both of them?
Which type of studies are you doing?
This will give me an idead to which extinct certain information is needed..
Kind Regards,
Message 5 of 9
(4,369 Views)
The no was an answer to your question. I have no experience with LabVIEW.
I'm studying industrial ingineering elektro mechanics.
Maybe there is a tutorial or something that i haven't found yet?
Message 6 of 9
(4,366 Views)
Hello Joris,
I would first advise you to go through this document:
https://learn.ni.com/learn/article/labview-tutorial
This should give you a better grasp of what you can do.
Kind Regards,
Message 7 of 9
(4,352 Views)
Thanks for the support!
Message 8 of 9
(4,320 Views)
Hello Joris,
Just let us know if there are issues that are coming up.
Kind Regards,
Message 9 of 9
(4,316 Views)
