Brushless dc motor control
I am using a brushless Dc motor 3 phase.. im confused on the six phase and the three phase. I am assuming the other three phases are for when it is high and when the state is low.. such like phase A high and phase A low.. I am using a VI that works with my hall sensors but the motor is twitching forward then twitching backwards.. what could be the reason for this I have attached the code.
(3,943 Views)
I don't know much about the details of the low-level motor control signals, but I thought it might help if I showed you a couple links.
Here is some example code provided by someone who apparently created an RT-FPGA 6-phase Brushless DC motor controller. https://decibel.ni.com/content/docs/DOC-2424
Also, here is a link to an external website that describes the differences between 3-phase and Trapezoidal (6-phase) Brushed DC motors: http://www.motion-designs.com/images/DTrends_May_2008.pdf
Good luck!
Jeremy P.
(3,862 Views)
