Buffer Error
I am trying to set up a program which seems simple, yet I keep getting
Error -10403 whenever I attempt to configure a buffer. I am using a
PCI-DIO-32HS with Windows NT 4.0 (incl. Service Pack 3). The memory is
marked as allocated by Windows. I also am having a great deal of trouble
with an error whenever I attempt to set the sampling frequency with
Clock Config VI, both directly and indirectly (with, say, DIO Start VI).
Has anyone else run into these problems? I contacted NatInst Tech
Support and they can't seem to figure it out either.
Jon A. Rinkenberger
Atmospheric Physics Research Laboratory
Physical Science Department
Embry-Riddle Aeronautical University
600 S. Clyde Morris Blvd.
Sent via Deja.com http://www.deja.com/
Share what you
know. Learn what you don't.
Message 1 of 1
(5,085 Views)
