Buffer Problems using NI PCIe-6353
Hello Kevin,
looks like that the last sequence changing avoids the error. Thanks for your help. I am going to change the trigger configuration today oder tomorrow. Maybe I have to contact you again because I am not really sure if I understand your changing ideas right.
Marion
Message 11 of 13
(693 Views)
Hello Kevin,
I tryed to change the trigger, but I am not sure how to do it right. I only found examples were an external trigger source is used. Can you just give me a hint, how to use this trigger function with is given from LabVIEW?
Marion
Message 12 of 13
(689 Views)
I'm not near a LV machine and have just a couple minutes.
I don't know exactly what problem you're having with configuring triggering for the CO task, but I think you can get some guidance from one of the shipping examples (available from the "Help" menu).  You'll navigate down the example tree for Hardware I/O then Counter Output I think.
If this doesn't help, repost your back-saved code or at least a screenshot of where you do your CO trigger config.  Maybe try to describe your question or confusion in more detail -- I don't really know what "hints" to give that wouldn't already be explained in the context help for the DAQmx Trigger.vi function.
-Kevin P
Message 13 of 13
(679 Views)
