(Bug?) Adding an excel chart into a sheet
Has anybody experienced the following problem?
I've built a chart in excel, and everything is ok, but when i try to put it into a sheet, something fails. There's no error reported, but the Location property of Chart class fails, and my chart appears as an independent sheet. This works fine under Visual Basic, so i thought it could be some problem with LabVIEW.
I'm using LV 5.0.1f1 and Excel 2000.
Thanks in advance
(3,212 Views)
I tried to run a VI with the location method in LV 5.0.1 and received an error message. Tried same VI in LabVIEW 5.1 and 6.0 and it worked fine.
(3,212 Views)
Does this mean i MUST upgrade LabVIEW to make this work? Or is there a workaround?
(3,212 Views)
Well, I have a Labview 6i, but I don't know how put into charts in the same sheets?. Can you help me? I only put one chart in a new sheet. I send you my file, you can modified it to do that I want.
(3,212 Views)
