Bug: Built Real-Time app won't run if it accesses a typedef'ed shared variable node
I finished developing a Real-Time program that uses typedef'ed (clusters and enums) networked shared variables (SVs). It works fine when I run the program in Development mode. However, when I built and deployed it as a start-up app, it refuses to start. The VI monitor in the Distributed System Manager says that the VIs that use those SV nodes (and the top-level VI that references them) have "Bad" status, and the rest are "Idle".
To get my built program to run, I had to disconnect all the variables from the typedefs. Deleting the SV nodes made the program run too, but that's not an option.
Has anyone else encountered this?
Platform: LabVIEW 2012 (32-bit), NI cRIO-9076
Certified LabVIEW Developer
(3,039 Views)
Yes. See the following thread.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,023 Views)
