Bug: Color change of plot on wrong line
When changing the color of a plot in a mixed signal graph, there is a graphical issue that the Plot is "previewed" on the line above. Have a look at the screenshots, it's quite obvious.
We use LabVIEW 9 SP1 and are just changing to 11 SP1, but the bug is in both versions.
Message 1 of 9
(3,785 Views)
Thanks for your posting here. I tried to reproduce your issue but I couldn't. If I open the example of Mixed Signal Graphs, I can correctly change the color without any issue. I use LV2011SP1.
Could you try to open that example and see if you still have that problem?
If it doesn't help, you can try to repair the installation LabVIEW.
The example name is: Mixed Signal Graph.vi
Hossein
Message 2 of 9
(3,739 Views)
You're correct, looks like it's only happening if you have only 1 plot area.
I attached a modified version of the example and another screenshot. Note the 2nd green plot "preview".
Message 3 of 9
(3,735 Views)
I tried your vi again and no problem.
I think that you have problem met your installation. Try to install LabVIEW again and see if you still have that problem.
Hossein
Message 4 of 9
(3,727 Views)
The problem is only a graphical one, and only visible when you are changing the plot color. So only when the color choose dialog is open.
The installation is fresh, and I verified the same behaviour with other installations on different pc's from different installation media.
Message 5 of 9
(3,721 Views)
I see the behavior Dennis is talking about.  It occurs in LV 2012 as well.
Look at the attachment called  Graph Color Bug4.png and where he put a red circle.  It is putting an image of the line next to the Group tag when you try to change the color.  It should probably be changing the color of the line in the box next to the actual plot you are trying to change.
Attached is a version of the VI saved back to LV 8.0 in case anyone can try in an older version of LV and see if it occurred then as well.
Message 6 of 9
(3,698 Views)
It got a bit quiet suddenly. Will it at least get fixed in the new version?
Message 7 of 9
(3,658 Views)
I informed our R&D department to look at this issue. I cannot say when it will be solved or the next release will not have this issue but they will work on it and solve it as soon as possible.
Hossein
Message 8 of 9
(3,656 Views)
ok, thank you for the feedback
Message 9 of 9
(3,654 Views)
