Bug: Cubic Spline Fit error when some (x,y) weight(s)=0
I wanted to log this bug on the forum. I have already logged this with NI UK Support: CAR# 287065
I was trying to use Cubic Spline Fit.vi and control its behaviour using the "Weights" array input.
The VI doesn't like Weight=0 in some cases.
The error reported "Analysis:  The input must be non-zero."
The VI will work if the number is a very small but non-zero number.
Steps To Reproduce:
I have attached a VI to demonstrate the issue.
Run the program with Select=TRUE and new element = 1 The cubic fit will run OK without any error.
Change new element = 0
The cubic fit will run but this time the error is -20141 Change new element = 0.0001 The cubic fit will run OK without any error.
Change Select = FALSE
This will then use the Example Weights array. This is a real example of input I am supplying to this VI.
Set Offset = 1E6 i.e a small number close to zero.
cheers
David
LabVIEW 10.0f2, Windows 7 32-bit.
(2,934 Views)
the same problem in LV version 2017.
BTW, how can I find the status of CAR# 287065?
Regards, Ljubo.
(1,956 Views)
