[Bug?] Defer Panel Update not working when changing scale property
I found that Defer Panel Update [when True] does not work properly when changing the scale fit property of an intensity graph.
Try the VI.
When Defer Panel Update is True, and you change the Numeric controls, the Intensity graph is not updated (as expected).
But now change the "Z Scale.Scale Fit" button and.... the Intensity graph is updated (only the Z-color, not the axis).
This looks to be a bug to me!
Nicolas
(3,650 Views)
Hi Nicolas,
This indeed looks like a bug. I will do more research on it and file a bug report if it's not already filed.  Thank you for posting this information!
Yi Y.
http://www.ni.com/support
(3,610 Views)
I know that is an old post, but I just want to ask whether that bug has been fixed in any version as I believe I just came across the same bug in 2014 SP1.
Thank you,
weirpenguin
(3,096 Views)
This bug is still present in LV 15.0f2
(3,064 Views)
