Bug? - Disabling RTM of Strict Type Definition does not work
[LabVIEW 2010]
I have noticed the following issue:
I set a control as a Strict Type Def and disable the Run Time Menu in the Control Editor.
As it is a Strict Type Def the RTM option is removed for instances of the Control.
However, when the program is run the RTM is not disabled.
Workaround is to change it to a Type Def so the option can be toggled in the instance of the Control.
Certified LabVIEW Architect * LabVIEW Champion
(3,522 Views)
I'll tell you what, you seem to be stumbling over all kinds of things today!
Good work.  Keep reporting what you see.
(3,519 Views)
Thanks!
FWIW, I keep a list/folder/videos of issues because I think it is really important to provide feedback.
If I don't have time then I will come back later when I do and post them up.
I don't mean to be flooding the forums, it's just how I do my thing 🙂
(3,514 Views)
Okay.  If you are collecting things and posting them at once, that makes sense.  It's not a problem that you are flooding things.  They are all well documented issues you are presenting that hopefully others can confirm and NI can say "yes, there is something here, let's issue a CAR# and investigate further".
It just seemed like that by having all these issues posted at once, you were having a really bad, unlucky day today.Smiley Very Happy
(3,512 Views)
Hi jgcode,
Thanks for the feedback and the well documented step by step!  I couldn't find any documention of an existing CAR for this issue and I was easily able to reproduce it on my machine following your steps.  I'll work on filing a CAR and get back to you with the reference #.
Sarah Yost
Senior Product Marketing Manager
(3,487 Views)
Cheers.
(3,481 Views)
