Bug - Function "multiplier"
Hello everybody,
I noticed a potential bug with the function "Multiplier". Maybe there is a rational explanation but I don't see for this moment.
I did 80*10 and the result is 32 and not 800 ??? Why???
I joined a picture.
Thank by advance at the community
regards,
Régis
(1,783 Views)
Accepted by regis76
Your data type is a U8 or I8.  The value is being rolled over and so you get 32 (800 mod 256 = 32).
(1,774 Views)
Yes, the local variable with the number "10" is U8. I forgot. But I'm surprised the result was 32 and not 256?
I put U16 and my problem has been corrected.
I'm a stupid man. ^^
Thank you very much.
Have a nice day,
Régis
(1,762 Views)
It can't be 256 because a U8 can only b3 0-255.
It can't be 255 because when you do math on integers and the results go out of range, the value rolls over.  It doesn't stay stuck at the max or min.
(1,753 Views)
Ok, I understand better. Effectively, I thought the value blocked on max value 255 (and not 256, I did a mistake in my previous message, thank you for the correction).
Thank you a lot for your full explanation. Very clear.
I will sleep less stupid tonight ^^.
Have a nice day,
Régis
(1,747 Views)
The mathematical algorithm down in the processor does not do a range check.  It will just do that mathematical process and stop once 8 bits have been defined.
(1,731 Views)
