Bug In Builder LV2012 - VI reported BAD when building - Need a workaround ASAP
Hello Greg,
Finally I keep the Front and Block Diagram of a couple of VI and I got a successful build. But when I start the application, it report the main VI to be broken.
So what can be the next step to debug this issue?
LabVIEW ChampionArchitect
Message 21 of 30
(966 Views)
@DanyAllard wrote:
Hello Greg,
It's hard to say. I'd try keeping block diagrams for more VIs until the application isn't broken after it builds.
Greg Stoll
LabVIEW R&D
Message 22 of 30
(958 Views)
Is it possible to see what cause the broken VI in a build application. Do you have at NI some sort of tools that can tell this info?
Message 23 of 30
(955 Views)
We don't have a great way to figure this out. One problem is that even if the top-level VI is broken, that might be caused by some VI being "really" broken deep in the hierarchy.  Our only recourse is to debug LabVIEW, which can be a bit painstaking and is something only R&D can do.  If you want to go down this path, we would need a copy of your application, and I'd recommend going through the normal support channels.
Greg Stoll
LabVIEW R&D
Message 24 of 30
(952 Views)
Ok thank you Greg,
I will talk to my team about this. Is there a way to get prioritize for this issue. Currently this issue prevents me to deliver a new version to our client.
Message 25 of 30
(948 Views)
@DanyAllard wrote:
Ok thank you Greg,
I will talk to my team about this. Is there a way to get prioritize for this issue. Currently this issue prevent me to deliver a new version to our client.
Again, I'd recommend going through support - they have the ability to prioritize things like this. I'm just a lowly developer...
Greg Stoll
LabVIEW R&D
Message 26 of 30
(946 Views)
thank you Greg 🙂
Message 27 of 30
(942 Views)
Dany,
If you call support to open a service request, please PM me the service request number so I can follow up on it.
Jeff Peacock
Produce Support Engineer | LabVIEW R&D | National Instruments
Message 28 of 30
(925 Views)
I notice that I accidentally gave myself the title of produce support engineer. While it sounds like a fascinating job, that was intended to say Product Support Engineer Smiley Happy
Message 29 of 30
(913 Views)
PM sent
Message 30 of 30
(906 Views)
