Bug: Inifile read
Also, 0 or NaN, it'll still give error 19.
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 14
(1,607 Views)
I'm guessing that a keyword without anything to the right of the equals sign is considered an empty string because that is exactly what it is.  That is how you define an empty string.  Well, to be less ambiguous, you'd have beginning and end quotation marks with nothing in between, but since quotation marks are implied, nothing to the right of the equals sign is valid for empty string.  However, it is NOT valid for any kind of number.  IMHO it should throw an error 19.  After all, LabVIEW can't read your mind.  It sees a valid string entry so it assumes it's a string and that you are reading it incorrectly.
Bill
CLD
(Mid-Level minion.)
Message 12 of 14
(1,583 Views)
But by the same logic, shouldn't a missing parameter throw an error also? That's a bigger miss in the ini-file in my book. Yet in that case it simply uses the default, nice and quiet. I'll make a suggestion out of it.
You're fully correct in how it works and handles the missing parameter, as it is, in fact, just an empty string in this case.
/Y
Qestit Systems
Message 13 of 14
(1,556 Views)
/Y
What I am saying is that it is NOT a missing parameter.  No parameter implies empty string.  So LabVIEW considers the ini file to be correct and your implementation incorrect - you specified the wrong datatype.  I'm not sure I want a computer to start guessing user intent for this.  As it stands, it does throw an error telling you something went wrong.
Bill
CLD
(Mid-Level minion.)
Message 14 of 14
(1,535 Views)
