[Bug] Type Definition element names not updated inside Property Node
I discovered another LabVIEW bug:
Description: in LV2020, when you have a typedef-ed cluster, a change to the element names does not propagate inside the class property nodes containing this type definition.
Example: with a cluster containing 1 element named "OLD NAME", which I later renamed "New Name".
Result: the property node still outputs the old name, while a direct call to the accessor VI gives the updated name:
To narrow down the bug: it appears when only the typedef element names are changed. Any change to the element orders or data types will update correctly the property nodes.
Situation: I'm using EasyXML to store a cluster config, so element names are important. I cannot use the accessor VI directly because my class is wrapped into a DVR, so I can only use property nodes.
Find attached my example project to reproduce the bug in LV2020.
(1,588 Views)
Filed to NI R&D as Bug #3460106
(621 Views)
