Bug With Merge VI Place Object On Cursor
I saw a possible bug posted on a community 4 years ago, and confirmed the behavior is still there in 2015.  Can this get a CAR or explaination?
https://decibel.ni.com/content/message/112167
Basically I have a VI and I want to place its contents on my cursor.  This works fine if the VI is on the palette an duse the Place Palette Object On Cursor but the VI isn't on the palette.  So I provide a path to it and that is fine, but enabling the mergeVI does nothing, no placement of VI or contents.  Thanks.
Message 1 of 9
(5,432 Views)
Hooovahh,
There has been a CAR filed for the issue, but it was only a documentation change. Can you provide a screenshot or post a sample VI? Perhaps we can reopen it and investigate.
-Brandon
Message 2 of 9
(5,307 Views)
Was the documentation change to remove this feature?  Because I want this feature to work.
Were you not able to reproduce this issue?  Attached is two VIs that demonstrate how this one function doesn't work right if Merge is set to true.  Run the Demonstrate Bug which will make a new VI then place a VI on your cursor in that new VI.  If you set the Merge to True nothing happens.
As far as I can tell it is as simple as, putting a true into it causes it to do nothing.
EDIT: Saved in 2015 but I've observed this in other versions and the post being old makes me think it goes back to at least 2010.
Message 3 of 9
(5,295 Views)
Hooovahh,
Thank you for highlighting the problem. We will consider looking into the CAR and moving further with the issue.
Thank you,
-Brandon
Message 4 of 9
(5,240 Views)
Any closure on this?  Is it a bug?  Is it poor documentation?  Is there a CAR?
Message 5 of 9
(5,024 Views)
Hooovahh,
A CAR regarding the issue was opened in 2010. However the CAR was closed/deferred in 2012 without adding the functionality due to lack of priority. It appears the develpoment team also decided not to modify the documentation/help for the function.
-Brandon
Message 6 of 9
(4,991 Views)
@brandonj wrote:
Hooovahh,
-Brandon
They were busy creating new icons.  😉
Bill
CLD
(Mid-Level minion.)
Message 7 of 9
(4,970 Views)
Okay, can I request the CAR be reopened so that the function bug can be fixed, or documentation updated to note the behavior?
Message 8 of 9
(4,951 Views)
Hooovahh,
I will relay your request to the development team.
-Brandon
Message 9 of 9
(4,920 Views)
