Bug each time I build an application
With v2009f2, after building executable, If I build an installation or an other executable labview freeze.
Thanks for your help.
Patrick
(2,408 Views)
Hi Patrick,
So when creating an executable LV stucks during the build?
Does this happen with every VI?
Did you just build something simple like a loop with timing and an indicator for the loops iteration terminal and then create an executable out of it?
Where you able to create executables before you installed the f2 patch?
What's your OS?
Christian
(2,392 Views)
