Bug found with tab control in 6.0
I found this bug and figured this is a good forum for both users and NI to
find out about it.
Place a tab control on a front panel and create a property node, select 'pages'
(which is an array of refs to each tab on the tab control). Index one of
the refs into a property node, it becomes 'page', select either 'page enabled
state' or 'page visible' from the available properties and connect the right
type of data in. In the development enviroment the code works fine to either
show/hide or enable/disable a tab, but once compiled into an exe the code
no longer works. Changing the state does nothing, all my tabs are available
all the time. I need to disable or hide one tab depending on permissions
avaiable.
NI - do you
have a fix for this?
Jared
(2,817 Views)
This has been fixed in LabVIEW 6.0.1 You can download this from our drivers and downloads section at www.ni.com/support
(2,817 Views)
Thanks for the reply, but i'll wait. Here is the warning from NI on thier
download site :
Warning: If you are using the bundle/unbundle functions or the LabVIEW Datalogging
and Supervisory Control Module, do not update to LabVIEW 6.0.1. National
Instruments expects a new LabVIEW patch available within the next three weeks
to resolve the incorrect behavior of those functions and the conflict with
the module that occurred with LabVIEW 6.0.1. Please update to 6.0.1 only
if you require a fix to one of the specific issues listed in the readme.txt,
and you do not use the bundle/unbundle functions or the module.
I dont know too many peolple who dont take advantage of clusters (i.e. error
in and out).
Jared
Stuart wrote:
>This has been f
ixed in LabVIEW 6.0.1 You can download this from our>drivers
(2,817 Views)
