Bug in LV 7.1's handling of double-click events.
NI Support,
In my application, user selects item from a listbox with a button or a double-click. Desired behavior is for the listbox to advance to the next item (mod array length) after button press or double-click. Labview processes the button press correctly, but the double-click is handled incorrectly, as follows:
Labview catches the double-click event and passes to my application for processing. I process the event and advance the list. Labview then throws a second untrappable event that "selects" an item in the listbox based on the original double-click location. Since this processed after I have already completely my response to the double click, it has the effect of undoing my advance. Workaround is to add a few hundred ms of delay before acting on the double-click event.
The attached VI illustrates the problem.
By the way, it frosts me that I cannot mail applications engineering directly without an active support contract when filing bug reports. Filing bugs is not requesting support; it is helping NI make LabView better. It takes time to rewrite a malfunctioning VI in a way suitable for submission to NI as a bug report.
Sincerely yours,
Rob Calhoun
(2,727 Views)
Working with events can sometimes be interesting.  I concentrated my efforts more on fixing the issue than trying to determine if this is a bug or not.  I modified your code slightly to filter events based on click type and I think it is working the way you intended.  Let me know it is not quite right.
(2,720 Views)
Chaos,
I still think this is a bug, but your workaround is much nicer than mine! I had to add a substantial delay to the event processing to reproducibly obtain the result desired, and there's no guarantee that would work right on another machine. Yours works without adding any delays.
(2,704 Views)
Hi Rob,
Thank you for your feedback. R&D is aware of that issue and is working to improve it in future versions of LabVIEW. We are also working to improve the bug report process from our website. I apologize for the inconvenience.
Chris J
(2,679 Views)
