Bug in array indicator?
I found very strange behaviour of Array Indicator (LV 8.20).
If you look at attached VI, you will see that is very simple VI where only first element of Array should changed randomly every half of second while other element are 8.
But if I click any element in Array indicator and move mous cursor over it, its value is changed although it should be 8 (see attached video).
Does anyboby know why is this happening?
Thanks!
(4,355 Views)
Waow... funny bug... A quick work-around would be to set the indicateur as "Disable", but then the user won't be able to use the "index display".
Smiley Surprised
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,341 Views)
Same behaviour with LV8.2.1 but no problem with LV8.0.1 and LV 7.1 (WXP SP2).
It seems to be a "display only" bug !
(4,340 Views)
Good observation JB - if you create another array indicator on the same wire, only the one with the cursor in it shows the incorrect data, so I'm pretty sure it is display only like you said.
This was reported to R&D (4976H91W) for further investigation.
(4,324 Views)
This is in fact exactly the test I made...
(4,317 Views)
