Bug in converting string?
I think that in Labview 5.01, the VI 'convert from exponential" is
expected to convert strings with 0-9, E, e and . caracters into numbers.
But it doesn't. You have to put commas (,) in your strings.
i.e:
3.5E-6 will be converted into 3
3,5E-6 will be converted into 3,6E-6 (rightly)
Does anyone already noticed that?
(5,697 Views)
See labview online help under 'VI Localization'>'Period and Comma
Decimal Separators'. I haven't really played with the setting that this
help topic discusses, however, it may be a good starting point for
discovering what is going on.
ej
In article <3794AA1E.BE42AEA7@lure.u-psud.fr>,
numbers.
> i.e:
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(5,697 Views)
> i.e:
This probably has to do with the locale settings. LV supports
both local and US decimal settings depending on various settings.
I believe there are previous postings that cover this in great
detail, and it should be in the manual too.
Greg McKaskle
(5,697 Views)
