Bug in quick-drop insert
BTW, wasn't the quick drop insert supposed to connect to several wires if it could in 2012? Selecting a visa ref and an error wire i'd assume i'd get 1 visa function connected to both with my insert, not 2, 1 inserted on each wire.
On the same note, Quick Remove makes some strange choices at times. It happily reconnects int-wire to int-wire regardless of their names ...
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 13
(2,431 Views)
/Y
Multi-wire insert can be accomplished by holding shift when you press the shortcut.  This goes back to at least 2010.  I assume this is what you mean..
Tim Elsey
Certified LabVIEW Architect
Message 12 of 13
(2,426 Views)
Thanks Tim, that was what i was refering to. I'm pretty sure that's one of the features they showed in "What's new in LV2012" on NI week ... oh well. 🙂
/Y
Qestit Systems
Message 13 of 13
(2,408 Views)
