Bug on Unflatten From String function?
labview 5.1.1
NT4.0
Im not sure why somehow this function cannot unflatten the data from "Get
Control Value" 's invoke node but so far when I try to probe it, there is a
valid data coming out of the Get Control Value and also from Type Descriptor
but nothing is coming out of the Unflatten from String function.
Does somebody sees the same problem? Or am I doing something wrong again?
TIA,
John
(3,942 Views)
It's confusing, but the "Type Descriptor" output of the Get Control Value method
should not be connected to the "type" input of Unflatten from String. Instead,
the type input must literally be the data type that you expect to emerge from
the right-hand side of the Unflatten from String node.
For instance, if you expect to get an array of clusters out of the Unflatten
node, then you need to wire in a dummy cluster array that matches the expected
output typ
e. If you wire in the Type Descriptor (an I16 array) instead, you are
telling LabVIEW that you expect the Unflatten node to produce an I16 array.
Even if this is truly the case, you should probably resist the urge to wire
these two terminals together, for the sake of clarity.
John Lum
(3,942 Views)
Thanks John. Everything is clear and working now.
John
"John Lum" wrote in message
news:38D704B4.60BE1DC@alum.mit.edu...
"Get
is a
Descriptor
method
Instead,
from
node.
Unflatten
expected
> output type. If you wire in the Type Descriptor (an I16 array) instead,
you are
array.
wire
> Regards,
> John Lum
> National Instruments
(3,942 Views)
I've used this function pretty often, but I've never seen the type terminal
used. What is its funciton?
John Lum wrote in message
(3,942 Views)
I think this was covered in the Msg from John Lum.
The "Type" terminal is used to tell the function
what datatype (ie I32 array, DBL, etc) is in the string.
Kevin Kent
(3,942 Views)
