Bug? tip strip confusion with variant in place element structure
When looking at an in place element structure with the Variant To / From Element Border Node, the tip strips when hovering over the terminals seem scrambled.
The lower left (type) input give a tip strip of "error out" (???) (see image below) Should be "type".
The other terminals don't have a tip strip at all, should have one, same as the name described in the help page linked above)
(some other IPE terminals (e.g. in place in/out) also don't have a tip strip)
Observed in LabVIEW 2011 SP1 and LabVIEW 2012.
(3,366 Views)
Hi Altenbach,
Thank you for bringing this to our attention, this appears to be a currenlty opened CAR #325150.
-Jake B.
(3,323 Views)
