Bug using array in formula node, LV6.0
Pass a 3-element integer array, containing values 5, 6, 7 into a formula node as input variable x. Pass variable y out. The formula node contains:
int32 y;
y = (x[2]-x[1]);
My result is 6. If the parentheses are removed, the answer is 1. Apparently adding the parentheses causes the expression to be evaluated as y = x[2-1];.
Has this been found/fixed? I have mailed NI separately.
(3,603 Views)
"Bill Atkins" wrote in message
news:506500000008000000BB560000-1027480788000@exchange.ni.com...
> node contains:
> int32 y;
> y = (x[2]-x[1]);
It works correctly in 6.1. I'm at home so I can't try it in 6.02.
(3,603 Views)
In 6.0.2 it returns 1 in both cases.
"Adam Russell" wrote in message
news:ajcc8d$1a266r$1@ID-122512.news.dfncis.de...
> > node contains:
> > int32 y;
> > y = (x[2]-x[1]);
ry it in 6.02.
(3,603 Views)
Thanks for checking this. I'm glad it's been fixed (or was it my imagination to begin with?).
(3,603 Views)
Bill,
Did you use; LV5, 5.1, 4.1?
Wiebe.
news:506500000005000000A3950000-1027480788000@exchange.ni.com...
(3,603 Views)
I used LV 6.0. I sent that info to NI, but I obviously forgot to include it here. NI wrote back saying the problem should be fixed in 6.0.2 (as others have said).
(3,603 Views)
