Bug when using Edit in Server Option while editting HiQ node.
I have recently started using HiQ nodes in my applications, but am running into problems. If I enter the "Edit in Server Option" and then change applications or click on another window without closing the HiQ server window I run into problems. I can no longer enter the "Edit in Server Option" and the HiQ program will not run. I can not seem to find the HiQ server window. The only way I have found around this problem is to close the current document, reopen it, delete the HiQ node and rewrite the entire code, and be very careful to always close the HiQ server window before doing anything else. Of course this is not a suitable solution. Has anyone else run into this problem? Have you figured out a fix?
Message 1 of 1
(2,451 Views)
