Bug with Image Display Control
I found a minor bug with the Image Display Control from the vision toolkit (version 8.5 of both).
Load an image into the control then
Select an ellipse ROI tool and select an elipse on the image (Notice the last bit of text at the bottom is the size of the ellipse you're drawing)
Now resize the elipse, notice now that the text is wrong (both values will be the width of the ellipse, instead of the width and height)
MattW
Message 1 of 1
(2,867 Views)
