Bug with XControl and Actor Framework
I have developed a multi-device DAQ program using the actor framework.
In one of my devices (actors), I use an XControl on the front panel.
I have a top-level actor which calls the nested device actors and summons their front panels.
I can use all devices with no issue, however, when I stop my program (and verify that all actor cores have stopped running), I try to unlock the Xcontrol library to edit my code.
However, the XControl refuses to unlock and claims that the device's actor core is still running, thus, I cannot unlock it.
I never start up that actor core, and can verify that it doesn't start.
Why does the Xcontrol think that it is running?
(1,980 Views)
Try stepping through your code (or put breakpoints at various places) while monitoring the XControl so you can find out when it locks.
I hope you don't have any instances of class objects in your XControl (that can lead to lockouts that can only be resolved by killing LV).
(1,958 Views)
