Bug with application builder and tdms vi's (LV8.2)
I build an executable that is using the tdms vi's. The source version is working beautifully but the exe doesnt read channel data. I then build an exe file from the TDMS file viewer VI provided with LV8.2. Same here, the exe doesnt read the channel data. Properties are read ok. Is this a known bug and is there a workaround? If not, how do I report errors like this to NI?
thanks
klaus
(3,014 Views)
Klaus,
what NI software (and which versions) do you have installed on the machine that runs your exe (LabVIEW, DAQmx, DIAdem ...) ?
Herbert
(2,999 Views)
Herbert,
I have LV8.2 (XP32), NIDAQ 8.0.5f3 and the demo of DIADEM 10.1
thanks for looking at it! I'm about to download 8.21 to see if it makes a difference...
klaus
(2,994 Views)
Have you tested LabVIEW 8.2.1 already?
Tomi Maila
(2,991 Views)
LV 8.21 has fixed this problem Smiley Happy
(2,984 Views)
