Build 8 bit binary number
Hello
I want to build a Binary/hexa decimal data from the buttons
Cancel is 1 bit data its the LSB, amnual/Auto is also 1 bit its the second bit
Noise gain is 4 bit data
Noise sign is 2 bit data
i want to build a binary number & equivalent hexa decimal number for this
Ex. if i click start error button the start error bit is 1 (LSB)
i select Auto, bit is 0
noice gain if i select 50% = 0101
noise sign if  Random 10
so i want to build a 8 bit data like this 10010101
thanks
sk
I am using LabVIEW 7.1
(4,157 Views)
Hello!
You can use "Number to Boolean Array.vi" and then concatenate all the boolean arrays you created. Then you can use "Boolan Array to Number.vi" to have your 8-Bit number. As attachement your modified programm. By 50% Noise Gain you have 0100 and not 0101 (Noisee Gain 50% has index 4 -> 0100)
Best regards
Ken
(4,151 Views)
Hello sk,
just try this...
(For the number controls I adjusted the range properties.)
(4,145 Views)
you've just to multiply Auto/manual by 2, noise gain by 4, noise sign by 64
and to add all the components.
look at the diagram here : http://cjoint.com/?gxq32THb1m
jerome
"LV Beginner" <x@no.email> a écrit dans le message de news:
1151050208933-382629@exchange.ni.com...
> Hello
> &nbsp;
> I want to build a Binary/hexa decimal data from the buttonsCancel is 1 bit
> data its the LSB, amnual/Auto is also 1 bit its the second bitNoise gain
> is 4 bit dataNoise sign is 2 bit datai want to build a binary number &amp;
> equivalent hexa decimal number for thisEx. if i click start error button
> the start error bit is 1 (LSB)i select Auto, bit is 0 noice gain if i
> select 50% = 0101noise sign if&nbsp; Random 10so i want to build a 8 bit
> &nbsp;
> thanks
> sk
> q.vi:
> http://forums.ni.com/attachments/ni/170/191663/1/q.vi
(4,133 Views)
