Build_AB Error 13 occurred at Invoke Node
I've migrated from LabVIEW 2018 to 2022.  My application runs okay from source but will not build.
I've tried all the suggestions from here: LUDICROUS ways to Fix Broken LabVIEW Code with Darren Nattinger | GDevConNA 2022
Other posts about Error 13 suggest isolating different parts of the code to narrow down the problem VIs.
Please advise on other ideas.
error message:
Click the link below to visit the Application Builder support page. Use the following information as a reference:
Error 13 occurred at Invoke Node in AB_Engine_Write_Linker_Wrapper.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW: Failed to load dynamic library because of missing external symbols or dependencies, or because of an invalid file format.
Shareable board exclusively owned.
Method Name: Linker:Write Info To File
(1,302 Views)
Have you tried a mass compile?
(1,301 Views)
yes, I followed all the suggestions in the YouTube video, mass compile is included.
(1,272 Views)
Accepted by topic author bmann2000
Build_AB Error 13 came back to haunt me again.  A quick search online brought me back to this forum post, and I did not post the solution.  If only I could remember.
This time I am upgrading from Win10 Pro to Win10 LTSC and reinstalling LabVIEW 2022.  The project will not build on the new PC, Build_AB Error 13.
As the same project would build on another Win10 LTSC PC, I set about looking for differences between the PCs.  In MAX, I could see the good PC had LabVIEW 2018 and 2022 installed, so I added LabVIEW 2018 to the problem PC.  Now when I open the build properties I get a different error message, file not found.  Looking at C:\Program Files\National Instruments on both PCs, it appears they have near identical folder structures and installed files.
So next, I copied all the "LabVIEW" folders from C:\Program Files\National Instruments from the good PC to the problem PC.  Now the project .exes build again just fine.
I appreciate that this type of file copy is not generally recommended, but since I want all my development PCs to be identical, I figured it was worth a try.  I moved the originals to a temp folder to allow me to revert if needed.
(737 Views)
