Build App nmdk_gmms_cant_open_msm
I try to build an exe file, but build applicatiob stops with
error 26132
possible reason nmdk_gmms_cant_open_msm
I'm working with Labview 6.1under Win98 and I'm a proud owner of a developper set which should
include this feature....
Any hints?
Urs Bögli
(2,509 Views)
Hi Urs,
from the end of the error (cant open msm) i suggest it is a problem finding a msm file.
My installation has these files (31) in the folder applibs\distkit\redist\modules of the LabVIEW installation.
If you have the files there you have three chances:
1. Make a report to NI support
2. Reinstall LabVIEW
3. Put your application in a winzip file with folder names and send it to me (waldemar@hersacher.de). I will try to build the application. Your Winzip file should not exceed 20 MBytes because its my private address and I have to get it over ISDN.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,509 Views)
