Build Application
I have problems with the application builder.I've created an
application but it doesn't generate an .exe, it looks like a file
without any extension.
There is no problem with the llb, I have build applications before.
I have installed LabView 5.0.1f1 with Windows Millenium. There is some
problem with compatibility?
Thanks !
(3,841 Views)
hi there, I have tried simulating your problem. It seems like you have obmitted the extension .exe when giving it an application name.
See attached.
PS: I am not sure if there's any compatibility issues. I have simulated this in LV6i on Win2K
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,841 Views)
"Natalia López" wrote in message
news:f2ed6aae.0210021605.4e1fb064@posting.google.com...
> Thanks !
When you build an application you tell labview what to name it. You
probably forgot the .exe on the end. Just rename the file with a .exe on
the end and try running it. While I'm on the subject, if you copy the name
from the llb or vi be very careful to never forget to change the extension
or you may overwrite y
our work.
(3,841 Views)
What are you naming the application?
If you call it "application" you will get a file without an extension.
Call it "application.exe"
try putting the .exe extension on the file and it should default to the
LabVIEW icon. Assuming you did not use a custom icon of course.
-Leo
> Thanks !
(3,841 Views)
Also assuming you have the LabVIEW run-time engine installed also.
-Leo
"FLAnatic" wrote in message
news:REMm9.63996$9d3.2571745@news4.srv.hcvlny.cv.net...
> -Leo
> > Thanks !
(3,841 Views)
Thank You!!!!!!!
Now I can generate an exe putting the extension. But... I can't run the
application, an error occurs and requires the full developement of LabView
to fix errors.
You know what is the problem???
Thank you again and sorry about my very bad english
Natalia
(3,841 Views)
Did you install the run-time engine?
news:f2ed6aae.0210030736.1cc8fa38@posting.google.com...
> Thank You!!!!!!!
> to fix errors.
> Natalia
(3,841 Views)
