Build Array of Different Data Types
Guys, sorry for the newbie question, but I am new to LabVIEW. I currently have ~15 elements of different data types (a small array of doubles, Booleans, doubles and strings). My end goal is to output these elements into a csv that Excel can open with the elements all in different cells in a row. Currently, the VI uses a Build Array, and then does a "Write to Spreadsheet File" to write to a text file.
Because the data sizes are different, the Build Array function forces concatenation into one string, which I am then struggling to delimit since the data types and sizes are different.
Do I want to use a function besides Build Array to accomplish this? Or what is the best way to write these different elements to a csv?
Message 1 of 12
(5,913 Views)
Hi jvavra,
Convert all those data into strings, then build an array of strings to write it into a CSV file…
Message 2 of 12
(5,899 Views)
Let me see if I've got it: do a "Convert to String" on each input to Build Array BEFORE entering Build Array? And then Build Array *should* recognize that all the data types are now the same, and allow me to NOT concatenate into one string?
Message 3 of 12
(5,893 Views)
You wrote "I currently have ~15 elements of different data types (a small array of doubles, Booleans, doubles and strings)".  But you have no such thing because that can't exist.  All elements in an array are the same type.  To get help, post your code.
Message 4 of 12
(5,891 Views)
You seem to be confusing Build Array with Concatenate String.  But I can't tell what you're doing unless you post your code.
Message 5 of 12
(5,890 Views)
Unless I'm reading it wrong, it appears Build Array does a concatenate automatically if you have elements of different sizes.
See code here.
Message 6 of 12
(5,871 Views)
For all of your scalar values put a build array prior to your build array. This will convert the scalar to a 1D array. I believe this will get what you want.
You really need to clean up that block diagram. It's really hard to follow as you have lines running backward and it's very large.
Message 7 of 12
(5,845 Views)
Yeah, I mentioned it in another post, I inherited this mess unfortunately. This is only one VI that's part of a MUCH larger VI. Took me awhile to figure out what it was doing, and how.
Message 8 of 12
(5,834 Views)
Read the Help for Build Array.  Note you can choose to "Build" (e.g. 1D + 1D = 2D) or "Concatenate" (1D + 1D = 1D, length = length of 1 + length of 2).
Every element in the Array must be of the same Type.  For example, you can't combine a Push Button and a Rocker Switch, nor a Green LED with a Red LED.
When Building "vertically" (i.e. not concatenating), the Arrays do not need to be the same length going in, but they will be the same length inside the resulting array (with extra "default values" added to the shorter element).
You can learn more about this from the Help on Build Array.
Bob Schor
Message 9 of 12
(5,831 Views)
See code here.
There's no such thing as "elements of different sizes".
Message 10 of 12
(5,826 Views)
