Build Array
hi yup understood i need it to be the same as the other two above not the one that u have shown which is pink in colour but have two boxes attached to it
Message 11 of 46
(2,116 Views)
Can you rephrase that using at least three sentences?
Also include clear references. Terms like "other two above", "not the one", "same as", "attached to it" are too ambiguous to understand what you are actually talking about.
Message 12 of 46
(2,109 Views)
i need all the three indicators to be the same the bottom one has to be the same as the two above
Message 13 of 46
(2,098 Views)
There are no indicators on your picture (snippet), thus your post makes no sense.
Message 14 of 46
(2,093 Views)
What indicators?  Or do you mean the constants?  What exactly are you trying to accomplish?
Message 15 of 46
(2,090 Views)
yup sorry i need to create constant at the terminal "Array Type" and i need it to be the same as the two above as in the same constant as delimiter and format string with the single pink box generated but instead that i got .My objective is to programme to generate waveform from the solar energy i got.
Message 16 of 46
(2,089 Views)
You still haven't explained what are "the two above"!
Message 17 of 46
(2,084 Views)
It cannot be the same. The upper are strings and the lower is an array of strings.
Message 18 of 46
(2,082 Views)
Remove the numeric from the array container and place a string diagram constant in its place
Message 19 of 46
(2,072 Views)
so how do you remove the numeric and add the string diagram?
Message 20 of 46
(2,071 Views)
