Build DLL Programmatically - Change Function Name
I'm using the VIs in the AppBuilder\AB_API folder to create DLLs for VIs in a project. Everything is working, but I'd like to be able to change the function name in the VI Prototype dialog box. I can't find anything in the API to accomplish this.
I found VIs in AppBuilder\AB_Classes\Source\ExportedVI that look like they can do what I want called Get_Source_ExportedVI_Data.vi and Set_Source_ExportedVI_Data.vi, but they're part of a different class and I can't seem to get the class object that they want as an input from the DLL API.
Does anyone know how to do this?
(3,518 Views)
Ok, I got this to work by copying the VI with a name that matches the name of the function I want. This way, when I add it as an exported VI to the DLL build, it uses the new VI name as the function name. It works, but I don't really want to do it this way. I had to add a delay so that it waits for the new file to be added in the project before it tries to add it to a build, this seems like it could cause problems.
There has to be a way to do this more efficiently.
(3,485 Views)
Hi Marc,
This is a really good question. Let me look into this a bit more and get back to you.
I also suggest posting on this forum too:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=475309&view=by_date_ascending&page=2
FLash
(3,483 Views)
