Build Digital Signal
Hey guys,
I need to duplicate an analog waveform as digitally.   Can anyone show me a quick way to modify my current VI to gen the same signal as digital?
Zach
(6,009 Views)
Accepted by topic author super-neuron
Is this what you're trying to do?
-Ethan
(6,003 Views)
Ethan,
Is there a way to build digital signals from scratch?   I would like see that if possible.   This is however I novel approach I had not considered.   I'll see if I can make it work in my larger construct...
Zach
(5,995 Views)
Zach,
This example builds a digital signal from scratch and plots it two different ways.  I don't really like the Digital Waveform VI's, but that's just me.  I think they're a pain in the butt.  However, if you're dealing with large waveforms and using compression they might be much more efficient.  Good luck!
Ethan
(5,972 Views)
Ethan,
I would like to thank-you for these fine examples.   You've provided everything I need.   I agree that building them from scatch is a pain in the butt.   I will attempt conversion of AO signals whenever possible.
Thanks again,
Zach
(5,943 Views)
