09-13-2006 12:44 PM
09-14-2006 10:44 AM
09-14-2006
06:18 PM
- last edited on
06-10-2025
07:53 AM
by
Content Cleaner
Hi Branson,
I hope you're doing well. It sounds like what you are looking to do is create an installer package that will encompass your application and necessary drivers. In LabVIEW 8.0, you can create a build specification for both your executable and also one for an installer. In the installer, you can include installer packages for the drivers that you select as well. The following page in the LabVIEW Help discusses how to build an installer. Let us know if this helps answer your question!
Thaison V
09-15-2006 06:31 AM
09-17-2006
11:53 PM
- last edited on
06-10-2025
07:54 AM
by
Content Cleaner
Branson,
You are correct that you will need to have the LabVIEW 8 Run-Time engine, as well as the Vision driver components. There are a few issues with including the Vision components as an Additional Installers, which is discussed in the following KnowledgeBase. Let us know if it answers your question about including this installer!
Thaison V
12-21-2006 12:06 PM
08-20-2007 03:48 PM
I am new to this group and I having same type of problem. I have labview.exe file created with Labview8.2. I want to create a setup.exe file for a customer. My costumer don't have Lab View engine running on his machine. How can I create an Installer which don't need any Lab View engines on client machine? Thanks for your help.
Harkirat
08-21-2007 09:04 PM
