Build Error. Error copying file.
When I try to build an exe file a following error message appears:
The build was unsuccesful.
Possible reasons
Error copying files.
Source: C:\Program Files (x86)\National Instruments\LabVIEW 2012\resource\lvanlys.dll
Destination: M:\YUVAL\LabVIEW\builds\data\lvanlys.dll
Copy in Copy From Folder To Folder.vi->Librarian Copy.vi->AB_Destination.lvclass:Copy_File.vi->AB_Source.lvclass:Copy_SourceItem.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller<APPEND>
Details
Error 1 occurred at AB_Destination.lvclass:Copy_File.vi -> AB_Source.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
I don't see I do anything wrong
(3,445 Views)
Can you run your program or does it contain errors? Open it and double check that the input parameter on you Copy File VI is correct.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,441 Views)
Yes, the program runs. The build eventially succeeded under a different name, I don't know what was wrong at the first time. Thank you for the responce anyway.
(3,434 Views)
