Build Error: NMDK_AF_CANT_OPEN_SOURCE_FILE
We've created a dll called JAVSTSST.dll that is somehow killing our overall build process. The build is in LV 6.1. The actual error message is occurs right before an installer is to be created and is shown below
Error 26047 occurred at Build Application.vi>> Dist Call
Create Installer.vi>> Win Install Create.vi >> Win Install
Add Files.vi >> MSI DK Add File.vi
JAVSTSST.dll
Possible reasons:
Can someone point me in the right direction for solving this problem?
(3,397 Views)
Hey, I have seen this happen when people move/delete files that the application builder is pointing at.  You may want to remove your DLL file from the application builder and re-add it.
Hope this helps!
Dan
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
(3,380 Views)
For some reason the Remove button is disabled when I try to remove this dll.....
(3,374 Views)
Hi Jim,
This is probably because the DLL has been included as a support file for the build.  Please remove the DLL from your support files and try again.  After you remove the DLL, add it back, and build the installer.
Elizabeth S.
(3,369 Views)
Yes it was listed as a support file and I did remove it. However, for some reason it remains in the file distribution list with the Remove button disabled.
(3,369 Views)
Hi Jim,
Have you tried to re-build the installer all together?  LabVIEW is probably having a hard time locating a file.  Do you have duplicate files?  Have you moved files after including them in the build?  Please check all of the files that you are including and take a look at the following knowledgebase article:
What Does Error 26047 Mean in LabVIEW?
http://digital.ni.com/public.nsf/allkb/996042FE08EADE4586256C690051F8B9?OpenDocument
Elizabeth S.
(3,350 Views)
